I am finding it hard to believe that this laser is firing at 40 watts. I have another laser that is only 30 watts, and it cuts 3mm birch plywood at 30% power + 5% speed.
My Laserbox will not. And it seems all the preset material settings show 80-90% power on EVERYTHING. That’s insane!
I did create a test file and run square cuts at different speeds and power. Also used certified material with preset settings and it did not cut. It looks to me like 100% power is NOT 40 watts.
The only thing I can find that seems like it might be the issue, is the Out Power. There’s an answer on another post here that tries to explain, but it’s not clear.
Is the laser firing MORE consistently at 8%? And LESS at 15%?
Also, we do we not have the ability to turn this off?
