I found that after I used mblock I cannot control the mbotusing IR remote control (actually I haven’t tried the remote before), how can I make it work again? Do I need to register my remote with my mbot? (I’ve two remote I am not sure which remote is for which mbot),
IR remote not work (normal function like forward, backward...etc)
Hi shanemcmahon,
You can program to use the IR remote controller yourself or you can just reset default program for mBot and you can use the IR remote controller to control mBot.
Please refer to the FAQ “How to reset default program manually?” in this link to reset default program for mBot:http://learn.makeblock.com/en/mbot-faq/
Since you have two IR remote controller, you can use either one to control the mBot.
The problem is, after I programmed some simple coding (say just moving the motor), when connected to mblock, the motor keeps moving. I click to reset to default program, it have no response (no upload popup) , however, sometimes I’m lucky that it can be success, but most of the time not, why?
Hi shanemcmahon,
Please restart the mBlock if there is no action when click on restore default program.
You may try the latest version mBlock 3.3.3 : http://www.mblock.cc/download
