I have an mbot and i need to know how to use this claw (pictured below) any help is appreciated. Thanks.
How to use the mbot claw
Andreas
You need the RJ25 adapter to connect that to the mBot:
Then you can use the Servo block to control the servo in the gripper.
- the Servo block has 2 parameters - port and slot. Port is as usual, slot refers to where you plug in the gripper cable on the RJ25 adapter.
- in the desktop version ob mBlock, the Servo block is available in the Maker’s Platform extension
- just try out which angles in the servo block open or close the gripper as desired. You might need to use negative values.
system
