Hello
I have a Grove - OLED Display 0.96" from Seeed and a Arduino Uno.
But i don´t know how it will work.
I found no Extensions for this.
All Extensions just work with 16x2 LCDs.
Can somebody help?
Thanks
Hello
Can somebody help?
Thanks
There are many different types of displays, for each type usually requires a special library. Further, the extension is necessary to implement any standard functions display on the screen. To use these features in mBlock can be very uncomfortable.
Some time I wanted to do this extension but unfortunately the ordered display has been lost in transit, and until now I didn’t order it again.
I propose to create a topic with a request to create such an extension, maybe somebody will agree.
@nilashis @AbaddoN @OZM
Check out this link, it might help:
https://www.arduino.cc/reference/en/libraries/grove-oled-display-0.96/
@Best_codes yes, it can be done with Arduino ide but is there a way to do it in mblock with block based coding?
If you can give me the code you’re using to do it with Arduino IDE and some more info, I will make a device to do it on mBlock.
