How to pull out the Airblock battery from the Battery Charger and the Main Control Module in correct ways
Pull out battery from Battery Charger
When pull the battery out from the battery charger, no need to pull the handle, you can pull it out through the other two sides easily. Please refer to pictures below:
Pull out battery from Airblock Main Control Module
When pull the battery out from the Main Control Module, pull the handle on the left first which will be much easier to pull out the battery. Please refer to pictures below:
PS: To make sure the battery don’t fall off from sky in Aircraft mode and also make it watertight in hovercraft water mode, the battery was designed to have enough tightness while plugged into the Main Control Module. Kindly refer to the correct steps to pull out the battery.
FAQs for Airblock
