I’ve just used an old plastic food carton and cut holes in the side and front for the cabling and camera. As this box is outside I’ve kept the number of holes to a minimum. It’s worth having long enough jumper cables so the temperature sensor can hang outside the box. I was getting slightly high readings when I had it in the box with the lid on due to the small amount of heat produced by the Pi.
Some duct tape holds the camera in place behind the hole.Four female to female jumper cables are all you need to wire up the MCP9808 temperature sensor.But how to Connect the MCP9808 to a Raspberry Pi?
How to Connect the MCP9808 to a Raspberry Pi
Maggie
