How to build/compile mBlock?
How can I compile/build mBlock?
Can you provide a detailed description?
Can you be a bit clearer on what you are trying to do? Are you downling the mblock sourcecode from github or the binaries?
I’ve downloaded the source code and want to compile (because of a new translation).
Just found out, that I don’t have to compile it to test a new translation.
Didn’t know that mBlock looks at C:\Users<username>\Documents\mBlock\locale for the language files. :wink:
Where to put this file on Mac OS X? Edit: found it, but not all text is translated.
I tried to compile the sources.
Not in order to get a new translation, but to understand where the compile time errors stem from that I currently get when deploying sample code for the LED matrix.
I used FDT for Eclipse to work on the code.
Have not been completelly successful yet:
  • Some unresolved classes
  • Some undefined functions in MBlock.as
  • Some casting errors
  • Some missing *.wav files.
Has someone been successful in getting through this, e.g. with Apache Flex?
Any way, I didn’t find the formatter for MeLEDMatrix, so I wonder whether current source version has already been checked in into GitHub.
