I wonder how often I need to clean the different parts on the Laserbox, mirrors and lens daily I understand, but air nozzle and other parts? Cooling water, how long does it stay fresh? What intervals do You recommend?
How often do I clean the Laserbox and change water
tech_support
Actually there is no strict requirements for the maintance,if you can normal use to cut or engrave,then there is no need to clean the lens,but if you find there are many dust on the lens,you can clean the lens as well.
For Cooling water,there is no need to change if your laserbox machine can works properly,you can use it all the time,cooling water is just for cooling down laser tube while working.
Aisde,we suggest to maintance lens and air nozzle after laserbox working for 60 hours,but it depends on its working status.
system
