Hello, It seems like the default measurements for Makeblock XY are not fitting my XY Plotter. It goes too far away from where I put it on the computer screen. I was wondering what U can do to fix this.
Help with m draw xy plotter measurements
tech_support
Hi twarnercool2,
Please try or check the following points:
Set the home position:
a. Power off the XY plotter, then move the physical carriage to the position (X=0,Y=0).
b. connect the XY plotter to mDraw software with the correct serial port, power on the xy plotter. Then the mDraw will remember the physical position (x=0,y=0) as the home position. -
Make sure you have set the micro step resolution (the small white switches) to HHH on each stepper motor driver.
