Can you please make it possible or tell us how to use MakeBlock on the Apple iPad to have the mBot follow a black line using the line sensor. Is there a code already for this? Is it possible to do this on the iPad using Makeblock or mBlock Blockly? If not can you please make it possible ASAP and tell us? Thank you so much!!!
Help with line follower
tech_support
Hi Chason610,
If you are using Me line follower sensor, you can refer below codes to program which is part of mBot default program.
Line program should be uploaded, it cannot be tested in online mode. So Makeblock App and mBlock Blockly App won’t work. Please try mBlock App, and please note that mBlock App doesn’t support Orion/starter and MegaPi/Ultimate 2.0.
system
