HC05 Bluetooth Makeblock Mbot problem in Android APP
Hello. I am working on setting up mbot with HC-05. I got good results with mblock 5 and it works well in live mode.
But my main problem is in Android Makeblock software. In bluetooth search, no search result is shown and it is not connected to mbot.
First, I connect to the Bluetooth module, then I search in the software, but nothing comes up. Do you know the reason for this problem and is there a solution to connect Makeblock android app through HC-05 for mbot?
Thank you
The Android App has lots of problems like this. I do not have a solution. Hopefully mBlock will see you message and fix the problem.
Thanks for your time,
Best_codes
