Halocode Analog read
I am trying to connect a DHT11 Temperature Humidity sensor to Halocode. I have been able to get a reading of 974 by using the upload broadcast extension blocks to a sprite. I am also using he Analog Read block for the Halocode. However I can’t get the reading/data to change. The reading continues to display 974. I understand that Analog Read voltage is in a range from 0-1023. So I am wondering if there is a reason why the data would not fluctuate if the temperature rises or falls. Why is it constant?
Also if anyone knows how to convert that 974 to a temperature or humidity reading. Any insights are appreciated.
Maybe the extension is configured incorrectly? Which one are you suing?
