For the tech team would it be possible to re-focus the laser between multi passes, for example I cut a 6mm thick plywood with 2 passes so the laser would focus a 6mm first pass and 3mm second pass or 3 passes so 6mm 4mm and 2mm focus. Maybe add an option to the number of passes so if more than 1 pass is programmed you can tick a box autofocus to choose this option.
Focus multiple cuts
tech_support
Hello RegTaylor, for Laserbox, it’s not possible at the moment. Each time when you choose the right material, the focus length is fixed and cannot be change until the cutting or engraving mission is done. If you want to have different cutting or engraving performance during one mission, you can check the color block function and choose different settings for different areas. Hope this could help: https://makeblock.yuque.com/docs/share/9236bb15-e62e-4d60-9f1b-7d195428b25e?#LCWGN
system
