Extention center?
Is this the correct site where the extensions people create get published??
https://www.mblock.cc/extensions/
Hi OutoftheBOTS,
https://www.mblock.cc/extensions/ the extension here is for mBlock3 software.
If mBlock5, the mBlock Extension Builder: https://ext.mblock.cc
Here is the guidance for you, https://www.mblock.cc/doc/en/developer-documentation/developer-documentation.html
Thanks.
If I wanted to make use of other peoples published extensions for mblock5 where I find them??
steps when you want to share your project.
when you search for an extension for that driver
That doesn’t let me use other peoples extensions just mine. I can also use mine by just down loading and drag and drop without publishing.
can you explain the problem with the picture.
How do people share their own made custom extensions with everybody else??
You can share it with everyone like the first picture I took.
when you publish how do people find the block you have published???
Others can add the extensions created by third party developers when it published and reviewed approval.
Add the extension and the blocks will displayed.
Thanks.
