start processing code…
processing code by middleware of arduino_formatter
avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\jague\mblock-avr\temp\build\src\demo.cpp” -o “C:\Users\jague\mblock-avr\temp\build\src\demo.o”
avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\jague\mblock-avr\temp\build\src\MMA7660.cpp” -o “C:\Users\jague\mblock-avr\temp\build\src\MMA7660.o”
avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\jague\mblock-avr\temp\build\src\rgb_lcd.cpp” -o “C:\Users\jague\mblock-avr\temp\build\src\rgb_lcd.o”
avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\jague\mblock-avr\temp\build\code.cpp” -o “C:\Users\jague\mblock-avr\temp\build\code.o”
Command failed: avr-toolchain\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I"C:\ProgramData\mBlock5\IdeServicePlus\app\external\arduino\avr-library\variants\standard" -I"avr-library/cores/arduino" -I"arduino-libraries/makeblock/src" -I"arduino-libraries/makeblock/src/utility/avr" -I"avr-library/libraries/Wire/utility" -I"avr-library/libraries/Wire" -I"avr-library/libraries/SoftwareSerial" -I"arduino-libraries/arduino/WiFi/src/" -I"arduino-libraries/arduino/SD/src/" -I"arduino-libraries/arduino/Bridge/src/" -I"arduino-libraries/arduino/Temboo/src/" -I"arduino-libraries/arduino/Servo/src/" -I"arduino-libraries/arduino/Ethernet/src/" -I"arduino-libraries/arduino/TFT/src/" -I"arduino-libraries/arduino/SpacebrewYun/src/" -I"arduino-libraries/arduino/LiquidCrystal/src/" -I"arduino-libraries/arduino/GSM/src/" “C:\Users\jague\mblock-avr\temp\build\code.cpp” -o “C:\Users\jague\mblock-avr\temp\build\code.o” C:\Users\jague\mblock-avr\temp\build\code.cpp: In function ‘void loop()’:
C:\Users\jague\mblock-avr\temp\build\code.cpp:55:12: error: expected primary-expression before ‘/’ token
move(4, / 100.0 * 255);
arduino build failed.
Error when I export to Arduino
javi_24
tech_support
Please offer more information so as to locate the issue.
What is the main board?
What is the software version?
Operating system of the computer?
What is the your codes?
javi_24
This appear with one variable in the action commands in my mbot
This problem is with the version 5 firmware 6.01.107
Thanks a lot
tech_support
Thanks for the feedback, it seems something wrong in the software coding convertor. We have our engineers check that and should fix it in next mBlock 5 version. Sorry for the inconvenience caused. Currently please do not use variable for the power%
