Hi.
I have here a mBot Educational Robot Kit (STEM) and want to know which digital and analog sensors I have.
I notice only analog sensors like
Ultrasensor, line follower (maybe it is a digital), lightsensor, buzzer and rgb led.
Which ports do use the on board sensors.
As I can find the following information on board.
A0 a1 a2 a3 (-> I think these are analog connections) and on the other side 9 10 11 12 (-> I think these are the digital connections).
But whis sensor will use the digital numbers and how can I use it.
Kindly regards for any answer
Different digital and analog sensors on mbot
Dear Customer,
Here is the details about the main board of mBot, please have a look.
http://learn.makeblock.com/en/mcore/
Four color-labelled RJ25 connectors for easy wiring and expansion with more Arduino sensors.
Makeblock electronics was marked with different color.
Thanks.
Thanks a lot for your answer.
I now that there are more different sensor available.
But I want to know which digital sensor are already on board in the educational robot kit.
My opinion is the port 13 digital.
I find the following code:
#include <MeMCore.h>
void setup()
pinMode(13,OUTPUT);
void loop()
digitalWrite(13,HIGH);
delay(1000);
digitalWrite(13,LOW);
delay(1000);
So the led will show for one second and hide for one second.
But on the same port 13 I can use the rgb led which I think they are analog:
MeRGBLed led;
void setup()
led.setpin(13);
void loop()
led.setColorAt(0, 0, 0, 255); //Set LED0 (RGBLED1) (RightSide) to Blue
led.setColorAt(1, 0, 0, 0); //Set LED1 (RGBLED2) (LeftSide)
led.show();
delay(500);
led.setColorAt(0, 0, 0, 0); //Set LED0 (RGBLED1) (RightSide)
led.setColorAt(1, 0, 0, 255); //Set LED1 (RGBLED2) (LeftSide) to Blue
led.show();
delay(500);
So maybe port 13 is analog and digital.
Is there a port in the educational robot kit which is only digital?
kindly regards for a further answer.
Thanks for your answer.
I thought when I can use the different rgb values it is analog.
Can you informe me which sensors are analog?
Kindly regards.
Thanks again for the answer.
Can you informe me where you get the information of the different colors.
May there exist a dokumentation.
Please send me a link.
Kindly regards
Sure, on our website-Orion introduction: http://learn.makeblock.com/en/makeblock-orion/
