I am trouble to identify the main difference between these 2 products. I found from one site stating that the MBot-S has a light sensor device, but said otherwise in other sites. Can I have an official confirmation?
Difference in Mbot-s Explorer and Mbot v 1.1
Hi stormingrobots,
I think you will know the difference between them by check the part list here.
Also I have send you the details to your email.
Please check your inbox.
Thanks.
For mBot Explorer.
For mBot V1.1
Thank you for the info. Just a recommendation. It will be greatly helpful if they are in “text” format, or even pdf as it allows users to search it.
Thank you, again.
Very simple to convert png to text using free online OCR tools
Part list MBOT V1.1
1 x Mainboard mCore
1 x Chassis
1x Me Ultrasonic Sensor
2 x Motor
1 x Mini Wheel
1x Bluetooth Module
2 x Wheel
2 x Motor Bracket
1 x Lithium Battery Holder
2 x Lithium battery Shell
2 x Motor Shaft Accessories
1x ME Line-follower Sensor
2 xTire
1x Screwdriver
2x RJ25 Cable
1x USB Cable
4x M4 x25mm Brass Stud
2 x mCore Shell_mCor
6 x M3x25mm Screw
15 x M4x8mm Screw
4x M2.2 x 9mm Self-drilling Screw
8 x M3 Nut
1x IR remote control
Part list MBOT Explorer
1 xMini Wheel
4 xM2.279.5 Screw
2 xPlastic Timing Pulley 90T for Motor
1 xMainboard mCore
1 xUSB Cable
1 x33120° Bracket
10 x4710 Plastic Spacer
4 xM4 Nut
1 x Building Instructions
25 xM4*8 Screw
3 xRJ25 Cable 6P6C-20cm
1 x 4AA Battery Holder
1 xUltrasonic Sensor
2 xmCore Case
1 xHOOk&LOOP
4 xM4*16+6 Brass Stud
10 x473 Plastic Spacer
8 xM3 Nut
2 xMotor
1 xBluetooth Module
1 xMe Line Follower
1 xmBot chassis
1x Line-following Track
8 xR2064 Rivet
4 xM4*14 Screw
8 xM4*25+6 Brass Stud
2 xSlick Tire
2 xMotor Parts
1 x2.5mm Screwdriver
1 xWhite Acrylic array board
6 xM3*25 Screw
1 xLED Matrix
1 x Quick Start Guide
