after 3 days playing around with my Starter Kit I’m experiencing a strange behavior of one motor: it rotates jerky. The other one does it smoothly, if they run separately. If I turn on both, both run jerky. After I swapped the motor connectors the behavior if the motors changed, so the problem must be the motor driver (M2). Its LED blinks slowly when I put small number on it and ca. 2 times per second with a maximum number of 255. It doesn’t matter, if I connect the board via bluetooth and control it from my phone, or connect it to computer an use the mBot software or use the Arduino IDE. It also doesn’t matter, is the motor is connected or not - the driver LED blinks any way. I updated the firmware several times an recharged the batteries, that I used all 3 days and that worked perfectly.
Are there any other tests possible to find out, what the problem is or ist it clear, that the board has become faulty?
