I am trying to create the application to detect the temperature and humidity readings using makeblock ide, Right now I am following the tutorials and need some advice about how can I create the application to detect readings from long range module as well a inform its wireless range distance and dbm readings while sharing the sensor data, Any suggestion which kind of wireless sensors will be useful and any sample to use for making application for Wireless sensor networks
Create the Monitoring application to detect the temperature and humidity sensor
henry76
Hey,
I can suggest you with the hardware which I am using with Raspberry Pi is wireless temperature sensor https://store.ncd.io/product/industrial-long-range-wireless-temperature-humidity-sensor/, but to make it use with makeblock IDE as per your requirement then you should go through documentation http://www.mblock.cc/docs/.
system
