Create extension with Python code?
Hello, where can I selecte Python code when I create an extension bloc?
I need to change the langage mode to be uploaded
I see this section, but can’t see where to select Python language?
http://www.mblock.cc/doc/en/developer-documentation/design-blocks-6-1.html#transode
Thanks
JL
I found, clic on the line where is written the name off the language.
@JLL To make an extension for a python device, you can go to
https://ext.mblock.cc/
and select add extension.
Then, select universal template:
Fill out your extension info (be sure to select a Python device) and click OK.
Now, select Python as your supported language:
And save your settings.
Then, edit your code!
