I try to drive my neuron car with the joystick. Forward and backward (y-axis) works fine, but for some reason left and right turn (x-axis) are stuttering.
This is my chart:
Best
Michael
This is my chart:
Best
Michael
Hi mlange,
It’s easier than your solution: Car
Otherwise, here is your solution with some adjustment
I adjust the speed of a motor when turning
thanks for your help.
The second solution works great for me.
If you are using the “Direction setting” in the first case, changing only the value of the direction doesn’t do anything. You have to accelerate the speed at the same time to make the car turn around.
Michael
