hi, best_codes! thank you.
the code you sent previously works for the remote controller - bluetooth and the mbot2…
is there a way to use the ‘joysticks’ to control the mbots vs the + (plus sign) control pad (upper left on bluetooth controller)
thanks
m
this is the code u provided last post about using the rmeote controller in get w mbot2
Control mBot Neo with Bluetooth Controller Joystick
magicmarc
Best_codes
Hi @magicmarc!
I’ve written a code for this that you can find here:
You will need to adapt that code to the mBot Neo (I wrote it for mBot). If you need help with that, please let me know!
Also, when you are done converting the code, posting it here on the forum would be useful for other people and for debugging if we run into any issues, so please do!
