Connection Laserbox to MacOS Catalina 10.15.7 not happening
Connection Laserbox to MacOS Catalina 10.15.7 is not happening
I have the Latest Laserbox MacOS Software Version 1.0.7
This is the installed firmware: 019.00-019.01-016.03-004.08-004.10-1
Please help!
you should install laserbox software to your PC,use that software to connect your PC with laerbox.
Here share the link for you to fix connect issue,hope this will helpful for you.
If there is no Type A connector in your PC,you cannot use USB to connect laserbox to your PC due to transportion compatible issue,you need use a extension connector via network cable to connect laserbox with your PC.
I’m not using PC, I’m using a MacBook Pro (2019) with MacOS Catalina 10.15.7. I have the latest Laserbox MacOS Software Version 1.0.7 installed.
Connection to Laserbox is not happening.
Can you help?
there is no Type A connector in MacBook Pro,if you want to use MacBook Pro to connect with laserbox,the only way is use Network cable.
