Is it possible to connect motors with encoders without a special driver?
- insert the motor into the ORION board, there is already support there, but encoders? Can I connect via RJ25?
The problem is that for some reason I have one engine driver with encoders dead. Now it’s not working correctly, I set another, it first worked fine, but after a while the motors began to work out of sync. This is noticeable compared to what it was. And the motor driver heats up. I applied to the orion 9v board from the power supply. And the program balances the robot. Could there be too many teams? Well this is not a question. I raised the question above.
