Does someone have a code example of using ssl_params parameter of mqtt.MQTTClient class? That parameter is mentioned on Python API for Third-Party Libraries page but beyond that I have only seen documentation on other web-sites for paho.mqtt.client module… and in those cases, when SSL/TLS is used, you need to upload a server certificate to the device. I’m not sure if it’s a roadblock for Codey or I just don’t know how to do it correctly. Could someone give an advice on that?
If uploading of the server certificate to Codey is not possible (and I probably just don’t understand some basics here), could someone clarify how ssl_params parameter should be used with mqtt.MQTTClient class?
