CNC machines are high-tech equipment controlled by complex software components. Any malfunction in their operation can lead not only to a reduction in the quality of machining, but also to a complete breakdown with resulting costly repairs. In order to avoid this, it is necessary to follow all machine care instructions.
Recommendations for the care of CNC machines
The following points are mandatory rules for the care of the machine tool.
- Cleaning the guide rails of chips and dirt. It should be performed only when the equipment is disconnected from the mains. Cleaning should be carried out with a cotton rag previously soaked in kerosene. After cleaning, the treated areas should be wiped with a dry cloth.
- Cleaning of milling equipment from iron shavings is performed with a lint brush. It is necessary to remove chips from the visible surface as well as from all hard-to-reach places.
- If the machine will not be used for 2-4 days, it will need to be wiped with kerosene, and then perform a thorough lubrication of all rubbing elements.
- If the machine has a liquid-cooled spindle, it is necessary to regularly check the correct operation of the cooling system.
- Oil and other liquids must be prevented from getting into the stepper motors, electronics and spindle.
- If the spindle has more than one mechanical gear, the shift knobs should only be used when the machine is running.
- Before installing a mandrel or cutter, the spindle bore and clamping bar must be thoroughly wiped clean.
- This is how you should care for your lathe and other CNC equipment. By following these guidelines, you will greatly extend the life of your lathe and save yourself from the need for costly repairs.
Where to buy CNC machines?
CNC equipment for various purposes in a wide range is presented inthis online store. Here you can always order the right model at an affordable price.
