I cannot upload code to mbot over USB from chromebook.
It works on PC and Mac but not from chromebook
I need to program the mbot, disconnect it from the chromebook and have it run on it’s own.
I found, one other user with the same problem but they did not get an answer.
Here what he said:
Please help. Just bought 14 mBots. 1 per student for coding in this new Covid-19 environment. Each student has a chromebook at their disposal. Was hoping it was a perfect solution. Here is my problem:
Finished the build today and connected the mbot to Chromebook via usb. Installed the mlink extension and was able to connect to the mbot through the ide.mblock.com 1 interface. I made a short program:
When mbot(mcore) starts up
move forward at power 50% for 1 sec
Switched to upload mode. Tried to upload and the upload fails telling me to check the logic in my program.
Switched to LIVE mode and changed the starting event to “when onboard button is pressed” and the robot follows the program perfectly.
Tethered robots will NOT work for class. PLEASE HELP!
I updated firmware to 06.01.107
I’ve also downgraded to factory (06.01.009) and tried the above with the same results.
I have the same problem. Tried it on different chromebooks still does not work.
Does it work on Chromebooks?
How do you do it?
Thank you
