Can't to add blocks with desired arguments
I’m trying to add a new device with my own blocks. but after extension was published , it didn’t deliver desired blocks. only appeared OPCODE content. please help. Thank
hey there,
please copy the key and paste in the “English” in “Translation setting” as below:
then it should be fine in the preview:
See gif:
Thank a lot for the support. I successfully corrected the issue. But still there is a little problem in block category menu. After publishing , it shows category ID instead of category name. please tell me how to correct it too. Thank
Oh sorry… I found the answer. That was because of my mistake. Thank you.
Hello @Sadev,
How did correct the block category problem?
Thanks!
Rodrigo
I found it. Translation was missing
Regards
Rodrigo
Hi Rodrigo,
Did you solve the problem? Yes , every single word should be translated in translation section.
Hi Sadev,
Yes, it was…
Regards
Rodrigo
