Cant connect to pc via usb or ethernet
Hello, when I try to connect my pc to the laserbox it only says that i should connect cable. Have tried usb and ethernet cables both. Any suggestions what to do? My colleagues computer works fine with usb, we both have windows 10.
Pls follow below steps to check again:
1.Uninstall current laserbox software which already installed in your PC,some files may delected by yourAntivirus sof tware.
2.Close all the Antivirus software in your PC,and install laserbox software again.
3.Install the driver for the laserbox for connecting,in this link you can check the details for CH34 driver installing.(pls select add new device while connecting with laserbox)
Pls contact with us if you still have any queries on laerbox.our support mail address is: support@makeblock.com
Thank you, will try it
