Hi!
I have recently bought a Starter Robot Kit.
I print the description of the product from Amazon.
At Point 6, it is specified that you can connect the device to mBlock5, but actually in mBlock5 you don’t have such an option. I saw mBot, mBotRanger, Codey Rocky and other devices, but not Starter Robot Kit.
If I try to choose mBot or mBot Ranger and upload the code to the device a message informs me that is “Please review the coding blocks or the code for this device. Make sure all the data, parameters and programming logic are correct or the device is properly connected.”
The device is connected and I have tested the program when connected the device by USB cable and the program is fine.
Also the update of firmware fails.
What should I do?
Description du produit
What is Starter Robot Kit?
Starter is a 2-in-1 robot kit. This Kit contains mechanical parts and electronic modules for you to start exploring the robot world, it can be used to build a robot tank or a three-wheel robot car. This Kit is a great choice for learning robotics, electronics and Arduino programming. It contains motors, Makeblock Orion controller, ultrasonic sensor, Bluetooth module (dual mode), structural parts, and hardware for you to start exploring the robot world. -
Main control board: Me Orion
Makeblock Orion is a main control board upgraded and improved for teaching and entertainment on the basis of Arduino Uno. With powerful driving ability and maximum output power of 36W (3A), it can drive four DC motors simultaneously. -
Easy but Powerful mBlock
Starter Robot Kits is fully compatible with mBlock which is a graphical programming environment based on Scratch 2.0 Open Source Code. It makes programming projects and interactive applications easier. -
Support Scratch & Arduino Programming
Learning programming is way more fun when your code controls a robot. Based around an Arduino board, this kit will teach you all about programming a micro-controller board to control physical objects using sensors. -
Further Exploration
- Electronic Add-on Pack for Starter Robot Kit
- Robotic Arm Add-on Pack for Starter Robot Kit-Blue
Note: Add-on packs need to be purchased separately.
- Supporting equipment+Programming Software: The Fun Way to Learn about Programming
Bluetooth Version: smart phone/ iPad/ Tablet/ PC/ Wireless Bluetooth Remote Controller
Infrared Receiver Version: PC/ IR Remote Controller - Programming Software
Makeblock App: App for controlling Makeblock robots with your mobile device
mBlock 5: A block-based and text-based programming software
