can’t connect to it via Bluetooth. Bluetooth will work only when USB cable connected to mbot ranger
Cannot connect to mbot ranger unless it is connected to PC
tech_support
You mean mobile App fails to connect Bluetooth, unless you connect usb cable to PC?
This should be cause by lacking of power. Please try some new batteries or recharge the battery, then issue should be fixed.
tech_support
Did you try totally new batteries?
What is the APP you tried? Another phone tested? Will you take a video of the issue process?
system
