Hello Tech_support,
I’m afraid I’ve found a small error in the generation of the Python code.
When I address elements of an array via the print statement, everything is fine.
When I address the same elements via the audio-play statement, inverted commas are placed as a matter of course.
This is at least inconsistent.
Otherwise: The command “Execute Python code” is excellent. It wouldn’t be bad if there was a way to determine where the code is inserted; possibly via a second command (1. def, 2. run)
Translated with www.DeepL.com/Translator (free version)
