Bot hangs very frequently
Symptom:
  • Turn on the robot
  • It plays the three tones of the default program
  • Then it starts playing (about 2 times per second) the same tone and blinking the blue onboard “L” labeled led.
  • This is very frequent when using bluetooth.
Already reset firmware and default program.
Regards
Hi fer_lopezbello,
Which kind of batteries do you use?
Once still the same issue even after you tried with good quality rechargeable battery, please kindly take a video for the behaves on mBot.
Energizer AA Alkaline. But I will double check if they are worn out.
