Board not visible if battery is not turned on
yesterday I could not see the board on mblock when I connected the printer cable to my lap top. The lights on the board did turn on. When I turned on the battery switch the board was suddenly visible.
I did not expect this.
Yes. That’s not a battery switch - that is the power switch. if the switch is off, you may only charge your mBot. This switch is necessary since there are certain cases you want to power off the robot while the moving parts (e.g. motors) is moving.
