Bluetooth disabled
hi i downloaded mblock for controlling my arduino when i connect with serial port it goes very well but bluetooth disabled how can i enable it? do i need bluetooth in my pc?
You’ll need to make sure that you’ve paired the Bluetooth module with your computer and then use the Connect->Serial Port and select the Bluetooth connection. Not sure which operating system you are using, but that is the general procedure for connecting with Bluetooth.
