Assembling 25mm dc gear motor
Hi Makeblock team and community,
My younger brother has accidentally disassembled both of the motors from the starter kit. Are there instructions to reassemble them? Can you help me?
[SOLVED] Need help assembling 25 mm DC Encoder Motor (9v, 86 RPM, 1:75 Gear Ratio)
Hey bud, looks like a mess! Is it down to the motor armature? Do you know if you have all the pieces? Compare both motors and see if you have two of everything.
Get back to me and I will disassemble one of mine step-by-step to reverse engineer yours! Sound Ok to you?
John did you get this reverse engineering project completed. I have the same problem and need instructions for reassembly.
Hi Nurbolat & fparker,
It is not suggested to disassemble the motors if you can’t remember how to assemble it again since we don’t have such instructions.
Here we can only disassemble one motor and provide the inside pictures to you for reference. Hope you can figure it out:
