Arrow Keys Not Working
Hi finally got everything working after almost giving up. Successfully connected via USB, connected via Bluetooth, and uploaded a simple program to the mBot. However, the only way the program works while the mBot is connected via Bluetooth is if I use my mouse to click on the Event.
For example: with “When up arrow key pressed, run forward at speed 100”: I cannot press the up arrow on my keyboard to make the mBot run forward - nothing happens. It only works if I use my mouse and click on the event “When up arrow key pressed”
Any thoughts on why my arrow keys aren’t doing what they’re supposed to?
Never mind - I was using a tutorial that I think wasn’t programmed correctly. Thank you!
