Hi there!
Did you have mext example file for ESP8266 Wifi Module?
Thanks!
I add esp8266 at extension and without block I have this error
Failed to compile file src/utility/EspDrv.cpp
arduino build failed.
Could you halp me?
Hi lucdag
here is the tutorial for how to add third party library,click the link below and get what you need.
Hello, @reowzi and @lucdag, if you are using Windows then you should be able to navigate to:
C:\Users\Your username*\mblock\exts\temp
and find it. It probably won’t be named Arduino.mext though.
*Your username is probably your last name, but maybe not. For me, it would be
C:\Users\BestCodes\mblock\exts\temp
Thanks for your time,
Best_codes
