Arduino extension in live mode
Is there any good example on how to implement an extension that works in live mode with an arduino ?
I read the doc, but I’m confused…
Hi sebdelprat,
https://www.mblock.cc/doc/en/developer-documentation/tutorials/how-to-write-sprite-role-extension.html
Here is a example for you.
Thanks.
Thanks a lot. Unfortunately, this is quite far from what I’m doing.
I’m programming a Arduino Uno Firmware for a Osoyoo Robot Car.
Using the GitHub code, I rewrote a basic firwmare. But now I would like to implement the live handler that uses serial port.
Could you show us some sample code (actually, any live handler from a mbot with some serial protocol would help a lot).
The serial protocol is described a little, here: https://www.makeblock.com/project/mbot-serial-port-protocol
The makeblock sourcecode in github (https://github.com/Makeblock-official/Makeblock-Libraries/tree/master/examples) includes source of standard firmware in the examples (e.g. Firmware_for_auriga) - in there you will find the serial protocol handler in the read_serial() and parseData() functions
The firmware is “easy”, that’s standard arduino.
I’m looking for the configuration of the device extenion: 1) how to write live handler that uses the serial protocol. 2) how to setup the firmware options (and all the others options) : what kind of file is expected where.
The main issue is that all the demos mext file I found on internet do not include the live mode, so I’m lost.
Hi sebdelprat,
Actually third party users don’t have the permission to use live mode and we can’t open the permission.
Hope you can understand.
