Hi All,
After adding library “Makeblock-Libraries-master” into Arduino 1.89. mBot 1.1 which change to using MeMCore.h, compliation error as followings,
Anyone know how to resolve this problem?
Thanks a lot, Sub
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: “Arduino/Genuino Uno”
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Sub\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Sub\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Sub\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\Sub\AppData\Local\Temp\arduino_build_794604 -warnings=none -build-cache C:\Users\Sub\AppData\Local\Temp\arduino_cache_911278 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.arduinoOTA-1.1.1.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avr-gcc-4.9.2-atmel3.5.4-arduino2.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avrdude-6.3.0-arduino9.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\Sub\Desktop\Arduino\mBot\Example_Code\Me_LEDMatrixTest\Me_LEDMatrixTest.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Sub\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Sub\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Sub\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\Sub\AppData\Local\Temp\arduino_build_794604 -warnings=none -build-cache C:\Users\Sub\AppData\Local\Temp\arduino_cache_911278 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.arduinoOTA-1.1.1.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avr-gcc-4.9.2-atmel3.5.4-arduino2.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.avrdude-6.3.0-arduino9.path=C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\Sub\Desktop\Arduino\mBot\Example_Code\Me_LEDMatrixTest\Me_LEDMatrixTest.ino
Using board ‘uno’ from platform in folder: C:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19
Using core ‘arduino’ from platform in folder: C:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19
Build options changed, rebuilding all
Detecting libraries used…
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “C:\Users\Sub\AppData\Local\Temp\arduino_build_794604\sketch\Me_LEDMatrixTest.ino.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “C:\Users\Sub\AppData\Local\Temp\arduino_build_794604\sketch\Me_LEDMatrixTest.ino.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\AppData\Local\Temp\arduino_build_794604\sketch\Me_LEDMatrixTest.ino.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\Me4Button.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\Me7SegmentDisplay.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeBluetooth.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeBuzzer.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeColorSensor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeCompass.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeDCMotor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeEncoderMotor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeEncoderNew.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeEncoderOnBoard.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeFlameSensor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeGasSensor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeGyro.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeHostParser.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeHumitureSensor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeIR.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeInfraredReceiver.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeJoystick.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeLEDMatrix.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeLightSensor.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeLimitSwitch.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeLineFollower.cpp” -o nul
“C:\Users\Sub\Documents\ArduinoData\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\cores\arduino” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\variants\standard” “-IC:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src” “-IC:\Users\Sub\Documents\ArduinoData\packages\arduino\hardware\avr\1.6.19\libraries\Wire\src” “C:\Users\Sub\Documents\Arduino\libraries\Makeblock-Libraries-master\src\MeMbotDCMotor.cpp” -o nul
