Arduiblock / Makeblock
I made this post because I have lot of problems with Makeblock and Arduiblock.
I bought the Makeblock starter robot kit (IR option) and I didn’t arrive to code with blocs of Arduiblock.
Is there a tutorial to understand what type of inputs and outputs to use Arduiblock and the relationship between block of Arduiblock and Processing for each block ?
Thank’s a lot
Thierry
Hello
you can use mBlock, it is developed by makeblock team based on scratch 2.0, you can download it from http://mblock.cc/
Thanks
With Scratch, the big constraint is that the program runs only the computer, not on the Arduino.
With Arduiblock, the program is downloaded into the robot (Arduino) and the computer can be disconnected with the robot. The robot will continue to function normally.
Mblock like Scratch or Arduiblock? Scratch firmware or not?
Thanks
Thierry
Hello
mBlock is designed on the basis of scratch2.0, With mBlock, those who are familiar with Scratch can easily interact with electronic modules in Arduino eco-system, you can also upgrade firmware or view source code of our main board mCore and Orion board.
Thanks
