I use Android phone to program a code for the aircraft. I use Makeblock 3.0.6 and just upgrade the firmware.
I think about to read the Ultrasonic sensor to build a altitude control program myself. I can not find the block for read the sensor. Could you give me a hint for using Ultrasonic sensor.
I check all of the blocks. I just guess the “read gyro on board (x,y,z) axis value” looks like relates to this, but it is strange to me. Normally, the gyro is read axis with roll, yaw, and pitch, but you shows x ,y, z. Could you tell me the meaning of your x, y, z axis?
Is there any guidance or block explanation in the Makeblock app?
By the way, there is “read temperature” block. I check the manual of the airblock. I don’t think there is a temperature sensor inside the Airblock master controller. What does the temperature for?
Thanks
