Using the remote control app for Android, it seems that the flight controls are reversed. When I pull back it seems to go forwards, and when I push forward it goes backwards. Has anyone else experienced this and have a fix?
Airblock flight controls seem reversed?
tech_support
Hi Theisler,
Have you connected all the power modules to correct ports on the master controller module?
Please make sure the Aircraft head power module is installed on Port 1 of the master controller module refer to the user manual:
Once still the same issue if all the modules installed correctly, could you kindly take a video to show your operation and the behaves on the Airblock, thanks!
