Just started playing around with my Airblock and programming. As usual with lightweight drones, flying outdoors is quite challenging even in a light wind. I was wondering if the gyros provide enough input to do automatic drift correction? If so, is this something you would consider adding to the firmware, or, even better, is there a way to do this with custom programming?
Airblock drift correction
tech_support
Hi Carpevita,
A windy outdoor environment will interfere with the aircraft’s normal flight. The Gyro will adjust the balance of the drone a little offset is difficult to avoid. While there is a adjusting function on the Makeblock APP, you can connect it to airblock and adjusting have a try.
For accurate calibration, this is very difficult to achieve even with adjusting on the APP, if you want to program to achieve accurate calibration, you may give a try.
