Hi everybody,
I recently bought two Makeblock 25mm DC motors from a reseller in the Netherlands. Running them, there seems to be a big difference between them. I have read issues others have had, and can not yet comment on whether they stall or lack torque. But one of them does not run “smoothly”. I have a comparison in the following video:
Note that the first motor seems to be spot-on correct with regards to the specifications: 200mA free-run current, which is on the edge of the “<= 200mA” spec.
The second motor in the video seems to encounter extra friction on every revolution. You can hear it from the sound (pitch going up and down) and see it on the current meter (current rising to 300mA once per revolution). Note that the only thing mounted on the motors is the light parts from the Makeblock motor kit, which weigh almost nothing so this is not the cause (shown by the fact that the other motor operates with it fine).
Normally I would not be nitpicking on a bit of extra current, but this is for a student project that has very tight power requirements. I am worried the motor will consume too much power / get hot / not deliver the required torque because of this “friction issue”.
What are your thoughts? Has anyone seen this happen? Can I contact my reseller and/or Makeblock to replace it?
Thanks!
Kind regards,
Sander
