Hello! How can I make interact two Codey-Rocky robots? I’ve neuron also…thanks a lot
2 robots
Hi Mileva,
There are a few ways to manage 2 Codey-Rockey.
IR
IoT (even possible between Laptop and Codey Rockey or another PC)
Post
Hi Crackel! Thank you for the answear. I’m really a newbee…
I tryed to connect two robots to my laptop: one by cable, the other by dongle, to have both in the same stage and then I tryed to make them interact by ir message, but I cannot. Should I use two laptops, one for each robot?
Hi Mileva,
There is why of possibility. You just have to insinuate what you are trying to achieve otherwise you have to start with simple things.
Look at my example.
Personally, I will use dongles if you have two. Since I do not have 2 Codey, I do not know if it works, I do not see why it would not work. Connect your 2 Codeys at the same time by adding a second device.
