After plugging the USB cable, my computer can‘t find the serial port?
1.You may forget installing the driver, you can find “install driver” on mBlock, also you can download from here: http://learn.makeblock.cc/driver_installation/
2.You may forget to start the Orion board, kindly check and turn it on, if you keep the Orion board off, computer couldnt detect the serial port.
3.After excluded the upper two, you can try another serial port or use another computer.If still any problem, you can contact support@makeblock.cc for further analyse.
