The smallest APA102-2020 LED
Everyone knows 5050,3535 led,now the smallest addressable led comes out that APA102-2020 LED,the size just is 2.02.00.9mm,which has much more advantage than 5050 led.It’s widely used in indoor display,full color display,advertising light boxes,soft light bar and so on.
APA102-2020 LED Datasheet:http://www.normandled.com/upload/201807/APA102-2020%20LED%20Datasheet.pdf
I hear there is another tinyest led now,SK6805-EC15 and APA102-1515 LED,the size both is 1.5*1.5mm,SK6805-EC15 has the same protocol with SK6812,APA102-1515 has data and clock dual signal.The protocol is the same with APA102.It can be used widely.
I have used many of the APA addressable LEDs including the small APA102-1515 that I brough from here http://www.neon-world.com/en/product.php
I mainly used them on a RPi because they have a clock line and can be driven from a SPI bus very easy without needing the precise timing of other addressable LEDs
I found the little 1515 were great for small robot projects :slight_smile:
APA102-2020 has updated version now,it have 2 types APA102-2020-256-6A and APA102-2020-256-8A
