mBlock 5 extension not publishing
I have created an ext with below mentioned details it works well with mblock5 desktop version but ext doesn’t appear in mblock5 web. please help.
ide: blue_brain_bot
Version: 1.0.0
Regards,
Abdul
Hi:
Can you provide your extension ID and general user information?thank you.
Version: 1.0.0
it just turns on and off led on selected pin.
Hi there
I mean the information like this:
Extension Name:Keypad 4*8 - V9ID:ext_0c38870f Extension Name:keypadID:ext_aba89aaa
Version: 1.0.0
@abduljarif Did you submit the extension for review?
Go to the “Publish Service” tab of https://ext.mblock.cc/ and click the dropdown to see sub-tabs:
Then, follow these steps to publish an extension:
  1. Click the “Extension Management” Tab.
  2. Click the “Publish New Extension” button.
  3. Type in the ID of the extension you want to publish.
  4. Select the extension you want to publish from the list.
  5. Add version details.
  6. Click “OK” to submit the extension for review.
You will see this message:
When done loading, you will see this:
The extension will be reviewed by makeblock and will be published if accepted.
I hope this helps!
Thanks for your time,
Best_codes
P.S. @CommandeR this is a Wiki post so feel free to edit it if there are details you want to add. :slight_smile:
Looks OK to me - @CommandeR
