Hi!, I’m new to mBlock(v3.3.2), which is running on Windows7. I downloaded it and tested some basics ok. Then just clicked on the “connect” tab and the program just stopped working.
It hapens only on that tab bofore showing the scroll-down. I say this because the same thing happens if I first click on any other tab whose scroll-down menus would show ok; but then, as I try to move the mouse pointer on to the connect-tab (to see its scroll-down menu), mBlock crashes as well.
Here is the crash-event description:
Name of Problem Event: APPCRASH
Application Name: mBlock.exe
Application Version: 0.0.0.0
Application Timestamp: 55de0777
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdaae
Exception Code: e0434f4d
Exception Offset: 00009617
OS version: 6.1.7600.2.0.0.768.2
Regional Config.ID: 11274
Thanks in advance for all help!
